Turn signal/high beam issues
Jet noise
Phoenix
Hey NAXJA,
I have an 01 sport, and have been having issues with my turn signals. Either direction, whe you signal, the lights will blink a few times, or sometimes not at all, and then stop in the illuminated mode. Also I've done the headlight harness mod and led truck lite upgrades, and now the headlights only work in low beam, switch g to high beam will turn them off.
So, I was pretty sure my problem was the turn signal switch, and I ordered a new one from rock auto (made by wells). So new switch installed and still the same problem. Now I'm at a loss as to what my problem could be, has anyone had this issue before? If so, what was your fix...
If the blinking stops, I would suspect the blinker clicker module.
The headlight thing may be related to the factory fog lamp relay. Use some Google-fu, I know there are some threads about that problem.
