lapaul
- los angeles
Reclently I've had trouble moving my shift lever into lst with my auto trans on my 90 xj. It just won't move past 3rd.
This has happened a couple times the last several days. I've managed to get into lst by moving the stick lever up and down thru the gears up to park and back down, until it finally got unstuck and went into lst.
I also had some problem moving it into park.
Once in lst it definately is in first since I used it going down very steep dirt hills in 4 wheel low and it really held the rig back.
Someone knowledgeable got under the rig and said it sounded right.
Any suggestions as to what is wrong and how I can fix it.
