I flush mine by myself annually, by pulling the tranny cooler return line and following the process that 5150 described.
Power flush setups force the fluid through the tranny at higher than internal pump pressures, which too often dislodges debris that has built up over time in passageways in the valve body, etc. This debris will often plug up check ball valves, which in turn, cause the tranny to malfunction.
