- Hammertown, USA
fdsa487 said:Okay here is the deal. My sway bars, when connected, slam into the springg on the passanger side and the spring on that side is also warped outward.
Thats a common problem. You have the axle twisted forward to turn your pinion up, and the coils are bowing forward and hitting the swaybar.
As was stated, lengthen your swaybar links by at least 1.5", your angles are all wrong there. if they don't go long enough, PM me and I'll trade you a set of the longer ones that I have as I need to get the shorter ones for my new setup.
Also, you can cut 1" off of your swaybar, grind the tube flat again and drill a new hole. I've seen a few guys do that.
-Cal
