TPS - repair or replace?
dmstumpf
Pasadena, CA
I thought I would find this in a search, but no luck.
I'm gettting some odd behavior from the AW4 - it seems to jump in and out of lockup (and sometimes hunts between 3rd and 4th gear) when cruising @ 35-45MPH. I'm convinced it is associated with the throttle pedal position. I think it's a bad TPS (just rolled over 180,000 miles on the original TPS unit).
Can this part be disassembled and cleaned? I'm pretty good with electronics, and thought maybe I could go cheap on this job. Or must I replace it outright?
Don't know about repairing it, but you can check voltages etc or borrow a spare good one to plug in to confirm it's the culprit before forking over the dough for a new one. I just picked up a new one a few weeks ago and problems solved (simular issues and milage to your situation).
also check to make sure the T/C switch on the brake pedal is adjusted correctly. That can cause T/C to hunt.
