Alrighty I just tried it.Have you tried letting it idle from a cold start to fully warmed up with the TPS disconnected to see what the idle does. Then very slowly give it some gas to 2000 rpm then slowly return it to idle? (do it slowly or it will probably backfire, hesitate and die with out the TPS connected). The idea being to see if the idle changes with out the TPS attached.
With out the TPS connected, the jeep idles to 900-950 after warming up.
Anything I rev it to, it drops back down to 900-950.
I put the TPS back in, and it idles at 900-950, and anything I revved it to it stays at 900-950.
You know, my friend drove it last night and said it idled at 900, not ever reaching 1300. What I did was reattached the ground wire from the TPS to the ECU ground, before I had a completely seperate ground going to the engine block. I also reset the TPS to 0.79 volts. Maybe that fixed it? I still would like to test the voltages at the ECU.
The shop I took it to awhile ago said they couldn't find any vacuum leaks. Wonder why it idles at 950. When cold it idles at 650 then progressivley gets higher and higher. I also replaced my throttle body gasket, and all the top bolts and two of the under bolts on the intake manifold are right tight. (He rebuilt the engine 50,000 kilometers ago) so I doubt that's the problem.
