jeepnuts311
- Atlanta, Georgia
what should be done with the other 2 wires?
-TIm
-TIm
KLXJ said:Got any pics??
krelja said:I've run across this site in the past and it seems to be pretty good for this stuff hope it helps www.12voltguy.com Good Luck
DaffyXJ said:Piece of cake, just did this a couple weeks ago.
3 wires control the solenoids. green, brown and black. Run these into the cab. I ran them in the passenger side on my 01 XJ through the grommet for the fan/a.c controls near the condensor canister. Pick up 12 volts inside the cab and run a short piece to ground. Use a single pole, double throw on-off-on switch. The green and brown control the solenoids in and out, common ground for the solenoids, 12 v power and ground to the center contact on the switch. pick a spot, drill a hole, throw on a red guard switch and you're done.
Great mod, no more running around with the remote cable hanging out the window, or getting rolled up in the window, the control unit doesn't flop around, and the winch is readily available when you need it.
Oh yeah, I have an M-8000 also.
Good luck
tdr1213 said:Well, the last two responses totally missed it. Their suggestion was where to buy parts. I have the parts. My question is "how do I hook it up?"
If you know anything about wiring up an in-cab switch for a warn m8000 winch please chime in because I need the help. My question is clearly stated two posts back.
thanks,
tim
