wcbuyer
- Raleigh, NC
It is time to replace my cracked exhaust manifold on my '99 XJ, 4.0, auto. 4x4. I have an APN on order and this is going to be next weekends (hopefully only 1 day) project. Are there any tips or secrets other then remove and replace per the FSM? I will spray PB Blaster on the nuts and bolts everyday. Would you use the gasket and doughnut that comes with the APN or get one from someone else? They said their gasket is a good gasket.
Thanks
Thanks
