mack
- gone fishin....
NICE!! did you make that stup?
DrMoab said:yup....shevey parts....7/8" tapered reamer,tubing and your set!
Love the rollover-red coils.DrMoab said:yup....shevey parts....7/8" tapered reamer,tubing and your set!
I use what works....they so far have done good for me....well since they have settled about two inches they have.Okie Terry said:Love the rollover-red coils.
It cost me 120.00 in TREs and tubing. My dad worked in a machine shop and did the threads on the tubing but I have heard you can buy the right tap if you know where to look.nhrocker said:DrMoab- Do you have an idea of what that cost to make yourself? (reamer included) Did you not need a steering stabiliser? Would one be a good idea on a DD and if so, how would you mount it?
IntrepidXJ said:IMO the passenger side does not hang down enough to justify a flip (and then messing with your trackbar mount to keep things parallel). The drivers side is worth it, as the tie rod does hang down more in the path of rocks, etc...
you can kinda see how little the drag link on the passenger side is down below the knuckle
this setup has worked well for me.
ECKSJAY said:
are you sure on that? I know Mike gets his linkages from WFO (wfoconcepts.com) at least on occasion, I thought it was all the time, and they use 1.25 .219 wallMike L said:That was where I got my STEERING as well. The only thing about Parts Mike linkage is that it is 1-1/8" .188 wall. We will have to see how it does on the rocks. Mike says the TRE will bend before the tube so we'll see.
-Mike
BrettM said:are you sure on that? I know Mike gets his linkages from WFO (wfoconcepts.com) at least on occasion, I thought it was all the time, and they use 1.25 .219 wall
mack said:does anyone have a pic of what the RHD draglink looks like on?
mack said:cool, is that the stock tierod with the flip kit?
