I went with moog, not the name they used to be but they looked better quality than the ones from the jeep specialty stores. Also Moog are behind some of the auto parts chain stores house brands, some of the part numbers and stamping on the parts give it away.
If I were you I would send that back and switch over to the ZJ tie rod and end. You get a solid tie rod (XJ is hollow and bends easily), beefier end and uses an adjuster sleeve.
