the official part upgrades off the wj
1badass4x4
I have access to a couple wj's for parts.What parts should i grab off them?
I heard the brakes can be bolted on rather easily,any more insight would be great.
I also heard the seats bolt right on but you need xj seat tracks,any other goodies to grab?
WJ lower front control arms can be modified to fit an XJ, or the XJ can be modified to fit the control arms. In either case, they have an "s" bend to them to clear big tires / wheels.
They are also boxed / stronger than channel
If you modify the XJ to take the arms, they provide a smoother ride.
WJs with the inline six (lord, I hope I remember this correctly), 04-06, had an intake manifold that is a nice upgrade to any XJ inline six.
I don't think the rear disc setup is easily converted to XJ use, but if you swap the entire front axle over to an XJ you pick up some performance & durability.
If i'm not mistaken the WJ has a low pinion Dana 30. Not as strong as the high pinion and worse drive shaft angles.
