Y2K-XJ
- Chandler AZ.
OK Guys and Gals This is the end to all your Death Wobble Problems.
Note: This is for XJ's running Stock length Lower Controll arms and a 2" minimum lift...
I have engineered a Spacer that swings the axle forward 1/4" bringing the Caster back to within Specs. (5 degrees)
Its very very easy to install!
It took me about 20 minutes and have absolutely NO DEATH WOBBLE anymore..
Its kind of hard to explain how it exactly works, The spacer goes in between the LCA Mount (attached to the frame) and the inner Bracket.. you just loosen the main Mount Bolt and the 2 studs on the backside of the mount and slip in my spacer and then retighten everything..
I have taken the liberty of making 20 sets of these spacers to help fellow Xjers out.....There 1/4" aluminum and fit Perfect....
I am charging $18.00+ postage(thats right Postage! They will come in a regular envelope) for a set of 2(thats all you will need) and detailed instructions on how to install them..
Please E-mail me [email protected] Pictures and more info can be seen on my website www.DTR.myjeeppage.com in the products section..
Let me know if your interested
