kenny811
- Damascus, OR
I get my parts from Oreilleys Auto.
Test this part most likely your problem. I thought my coil was bad also but it wasn't.
http://www.oreillyauto.com/site/c/d...1180178_3542&keyword=ignition+pickup!s!stator
Just went thru the whole shebang on my 99. Replaced O2 sensors, CPS, coil, distributor and ran fine for 20 miles then code popped up again. Same one over and over CPS bank 1. I cleared it and found wiring was really hot next to the block. I pulled the cap off and moved coil/distributor harness to the out side of distributor. Will see if that fixed it!
Is this also called the CAM position sensor (CPS)
Do most people change the sensor on the side of the distributor as well?
Worth doing every 100k, etc?
