anybody heard of this? i didn't know it was available. i've been researching lifts for a couple months and haven't come across it.
are there any pros to using a long arm kit? this is my dd and my weekened wheeler. sounds like a good kit, and at a real good price witht hte exception of the aal. might just look into this a little more.
TMI-SUSS4XL $604.95
OverviewBrand: TeraFlex Manufacturing
Product Line: TeraFlex Jeep Long Arm Suspension Systems
Primary Front Lift Component: Coil spring
Primary Rear Lift Component: Add-a-leaf
Front Shocks Included: No
Front Shock Quantity Per Wheel: 1
Rear Shocks Included: No
Rear Shock Quantity Per Wheel: 1
Brake Lines Included: No
Hardware Included: Yes
Quantity: Sold as a kit.
Maximize off road performance.
4 INCH LIFT SYSTEM XJ LONG ARM
These TeraFlex Jeep long arm suspension systems feature streamlined control bracketry that mounts between the skid plate and the frame, allowing easy access to the transfer case. They include front and rear coil springs, front sway bar disconnects, and the unique long arm design. The specially designed long arms provide improved handling and ride, and when used off-road, will give you the maximum amount of articulation and wheel travel.
TMI-SUSS4XL $604.95
