4wheelsgood
- Marin County, CA
About a week ago the temp gauge on my '88 4.0l started acting up. When it began, the needle would dip to the low range of normal whenever the RPMs exceeded about 2,000 rpm. It seemed like a possible stuck thermostat, so I replaced it with another OEM (195 degree) unit. The same problem continued, with the gauge acting more erratic - diving to 0 and moving way too quickly to reflect actual temp changes in the engine. But the gauge never went over 210.
I figured the sending unit was going bad, so I switched it out. Now the gauge acts "normal" (i.e., moves gradually up as the engine warms up, then hovers at a set temp). The only problem is, it sits well above 210, almost to the red zone. My engine has never run that hot, and I don't think it is now, because because my fan has always come on consistently at 210. The fan still cycles normally if I sit and idle long enough, so I know the temp reading is not accurate.
About the cooling system - it's a converted open system, with the fan switch in the original location on the radiator. Everything in the cooling system is less than 2 years old: radiator, hoses, water pump, and now the temp sending unit.
About the only thing left to replace is the temp gauge itself. Has anyone else had their temp gauge go bad on them, and start reading warmer? Could it be a bad ground somewhere? My engine is grounded well, but I am not sure about the dash. None of the other gauges is acting up.
Any ideas?
Any ideas?
