hormel26c
- British Columbia
I'm installing an aftermarket tach in my 1986 XJ (V6 3.4L ignition for a 2.8L) and am having some trouble as to where to pick up the tach signal. The HEI external coil is a Delco-Remy with plugs and I'm not certain which one to go to.
I was also thinking of just going to the instrument cluster since I believe Jeep has a line into the connector even if a tach is not installed. Is this true? If so, which wire or which pin number would be correct?
Many thanks for any help anyone can provide.
