T&T trackbar and HD mount
All though I have not installed it yet, mine came with one bolt, which is for the track bar to frame mount end. I am assuming you have to use the stock bolt on the axle end, unless I am missing something.
I think I just got an extra one. Both bolts I recieved were identical.
mine came with two Allen wrench bolts also but i used the OEM bolt. Make sure ur bracket bolts are tight and maybe even put a lock washer on them cause i ve snapped a tracbar mount and bent another one cause my bolts vibrated loose.
I used the two allen head bolts that came with it. I originaly used my oem one but I snapped that one on the trail. I'm glad I had the new one in my tool box.
Well, the allen head I was trying to use was too long. It was hitting the axle before I got it tight. And did you use a nut on the allen head bolt or the OEM piece that you thread it in (cant think of the name?)
What trail is that,I dont ever want to go there!:laugh3:
Well technically I was not on the trail when it happened. I had just finished and was in a parking lot and got under there to tighten it up because it was loose. I underestimated my own brute strength and snapped it like a little twig. :) This was on Medano Trail that leads into The Great Sand Dunes National Monument here in Colorado.
Oh and yes I just reused the oem nut, I was not able to get a new one in there. I was thinking about going to the dealer and getting a new one to use but its worked fine so far.
