Jeff 98XJ WI
- Butternut, WI
Ok, lets not get into the why do you want to do that. Instead, lets get into will this work, ok? I am considering redrilling the AW4 output housing to clock the t-case up a little. However, I can't go much. So, how close to each other can the holes be? Is there any reason I can't drill a new pattern offset from the stock one with the resulting holes having something like 1/16" of material between them? If needed, I could probably tap the stock set of holes and thread in an allen head plug to fill the holes. The holes do NOT need to be sealed or anything, my main concern is whether or not the holes can be spaced closely and not cause any sort of problem. I think it can be done, but I would like to hear your thoughts on whether or not it is a good idea. Jeff
