Well I have the NP242 and with no HD SYE option available to me, I am going with the next best thing... the hack and tap
Now I have researched this for far too long and I only need one more measurement before I go ahead and order everything
If you have read GoJeep's SYE [ http://www.go.jeep-xj.info/HowtoSYEconversion.htm ]I will be using a similar yoke from Jesse @ High Angle Driveline, obviously it will need a couple modifications but nothing too hardcore
Since I have a 96' case, I have the 1 piece tail cone that seals all the oil in. Now on GoJeeps setup, he has an older case that uses the RE seal, which I don't need.
So I plan to use Old_Man's flange setup and incorporate the yoke instead. This will allow me to butt the yoke against the output bearing just like GoJeep.
http://www.4x4getaways.com/oldmansye.htm
Anywho, "fergie" uses the Currie seal part number CE-9069TS and apparently this seal fits the O.D. of the currie flange perfectly...
Now I want to use the Currie seal in conjunction with the yoke from Jesse.
I gave Jesse these specs:
1.172 x 27-spline
1.50 seal diameter
1310 series U-Joint
"It must though also have bolt through U bolts where the nuts for the U bolts end up on the back of the yoke and not a saddle type yoke like the pinion end of the rear driveshaft."
He replied saying that he stocks a yoke to those dimensions so that kicks ass
I e-mailed Currie and haven't heard a response yet... I need to know if anyone on here knows what the dimensions (I.D.) of the seal in question (CE9069TS)
Or if someone knows the O.D. of the flange that currie sells, I can use that spec as well... either will work
1.172 x 27-spline
1.50 seal diameter
1310 series U-Joint
