XJ: '90 2 door, 4.0, AX-15, 231, slip-yoke driveshaft, 32's, Tomken 4" lift with 3" shackles; probably 4" total lift after sagging (5 yrs old). WJ brake master/booster upgrade
My D35 sounds like it is ready to give up the ghost. The thrumming sound it makes under load is getting louder, and it is starting to make a grinding noise while coasting under no load. I'm pretty sure it is the diff, as the lift has been on for 4-5 years with no noise (so I don't think an angle issue), and I replaced the ujoints (the originals seemed fine).
Like everyone else, $$$ is tight right now. Actually, very tight. But I need to fix it before I get stranded, as I need this rig daily for work. My choices seem to be:
1) rebuilt/regear current diff: I'm pretty much ruling this out, as the shop I trust wants $600 for the work, and I don't want to put that into a D35.
2) swap in a 8.25: I could do this swap myself in a weekend, and I have found 8.25s with the right gears locally, but they are all 27 spline
3) swap in a 8.8: I can also find 8.8's with the right gears locally as well. I can get the brakes working. I can't do the welding for the springs/shocks/tubes, and I don't know if driveshaft length will be an issue with the pinion adaptor.
4) swap in a D44: can't find any of these locally, and couldn't afford the gear swap on top of that.
My choices seem limited to the 8.25 or 8.8. Eventually, I'd like to get a LSD or locker. Based on my current (non)braking performance, I'd like to get some rear discs on it as well. My questions are:
1) If I get the 8.25 (easiest/cheapest), are there any lsd/locker options for the 27 spline (I've only seen them for the 29 spline). If I switch to 29 spline axles, can I do it with a locker upgrade, and avoid paying to re-set the gears? I know there will be an added cost to ugrade the brakes, but that can also be done down the line.
2) If I get the 8.8, I'd get the brake upgrade for free. However, I can't do the fab work to get it mounted. The shop I trust is willing to do the fab work for a reasonable price, but they want to install it also (understandable), and will need to have the truck for 2-3 days (I can't afford that). Also, they think the driveshaft might be too long (I have ~1.25" engage of the slip yoke with the current lift), and that the shorter line will cause greater angles, forcing me to go to a SYE/CV shaft. That's too much $$$$.
If the driveshaft length is okay, maybe I can find someone to carefully take measurements and fab up the 8.8. Is that possible, to setup it without having to trial/error testfit it? What are my best options and alternatives?
Thanks!
Thanks!
