MasterPull
We make rope cool
- Bellingham, Wa
Many of you may already be familiar with Master-Pulls line of synthetic ropes. We are the only company to offer different grades or qualities of rope that include MP Basic, Superline and Superline XD. Master-Pull Superline is a rope unlike any other out there. By starting with a larger diameter synthetic rope a unique manufacturing process allows Superline to be stretched down to a smaller diameter, this retains the strength of the larger diameter rope while reducing the overall diameter of the rope. This gives the highest strength to size ratio available for any rope available!
Because of the manufacturing process, Superline is a much denser and tighter woven line then lines like Amsteel Blue. This reduces the likelihood that a strand will catch while winching and damage the line. The dense packaging of the fibers helps keep grit from working their way into the line and damaging the rope.
The strength of Superline allows for a smaller line diameter to be used on a winch and also for more rope to fit on a drum. Check out the strength of Superline vs regular synthetics:
• 5/16ths Superline 21,000 lbs 5/16ths Amsteel Blue 12,300 lbs
• 3/8ths Superline 26,000 lbs 3/8ths Amsteel Blue 18,000 lbs
Here is a picture of Master-Pull Superline pictured with our new Winch Stop Thimble:
Like all Master-Pull products, these ropes are elligiable for a 10% discount. If you need a quote or have a question about which rope is right for you contact us and we can help you out.
To place an order call: 360 714 1313.
-Alex
-Alex
