AZ Jeff
- Gilbert, Arizona
GSequoia said:One thing about the clutch. I was just informed that a lot of the clutches sold by the usual auto parts stores have an issue. There are tabs taht extend forward from the clutch that are too long, they can eat your radiator. So look around and get the one with the most clearance you can find. Alternatively (if you're feeling like dropping some money) you can get one from the dealer and it will drop right in. Another alternative is to modify the new fan clutch's tabs by grinding them a bit.
I jsut got one from AutoZone for my '92, and the only issue I had was that the spacing between the front of the clutch and the rad is a bit shorter than the OEM type (which is made by Delco/Harrison, by the way). Thus, to put in the AutoZone clutch, I had to tilt the rad forward about 1/4 inch, to get the clutch past the mounting studs. Once installed, clearance was no problem--about 1 inch to the rad.
