azupcountry
- Florida
Evening all,
96 4.0 AW4. 240k.
After replacing cooling components back in October I have been enjoying a dependable worry free XJ on my 60 mile round trip commute..until..
A month ago while leaving home in the AM she stumbled with light throttle. Didn't make it out of the community. Borrowed folks extra car and started reading forum posts. Codes were 02 sensor and misfire. Replaced IAC. Ran great for a few days then same thing happened on the way home from work but the power went away, the idle got worse and worse until it died. Would restart but not stay running longer than 2 minutes. Had it towed.
Since then:
Both 02 sensors replaced
Intake air temp sensor replaced
Dizzy cap and rotor replaced (ran great for 40 miles-wouldn't restart next AM)
Coil replaced (mopar) no start
CPS replaced (mopar) started, ran great, idled high (1000rpm), stumbled with light throttle, slow 5 count to drop from 2k to 1k idle, turned off, no restart.
Tried putting old IAC back in, no start.
Not throwing codes (key turn method)
I do get fuel spurt at the rail but don't have a gauge.
I suspect that as before after a total cool down, it will start and run until I shut it off.
I don't have multimeter but can and will get one if necessary. Please let me know what you would do to track this down.
Thanks for any help
96 4.0 AW4. 240k.
Since then:
Thanks for any help
