So I have been battling a stumbling and general bad running condition at idle, I have replaced all obvious tune up parts, plugs, wires, cap, button, cleaned the TB, and replaced the IAC. I was beginning to think that it was the fuel pump since it whines pretty good, but the pressure is fine....... I was just outside fiddling with it and noticed that when I unplugged the Manifold Temp sensor (at least I believe thats what it is... it is on the manifold just behind the TB and has two wires on it) anyways it stops stumbling and runs fine when the MAT is unplugged?.... what are the symptoms of a bad MAT? and could this have been my problem all along? it is a :
1987 4.0 AW4 Stock motor and ugly as sin!
