vegeta
- ashland,kentucky
I've run into a little snag in my swap. I'm running a renix block for my stroker and swapping it into a 93 body with the 93 head accesories. The problem is two of the bolt holes aren't drilled on the renix block. the place where the coil bolts to the original block have the bosses cast in place but no holes. I'm not to concerned about the coil as it can be mounted somewhere else but there are two large wires that I think also went there. One goes to the alternator and the other goes into the harness. can I bolt these 2 together and tape them up? I may try get an right angle drill and drill and tap the because I'v got to replace the engine mount on that side anyway.
