4WDlifeform
- Beaver Falls, PA
Hey guys. Was out wheelin, and I have been getting a strange noise, coming from the front drivers side wheel area. Once I cleaned up the jeep, I crawled under to see if I could see anything going on. I noticed bare-metal-rub-marks on the spring, and on the drop bracket for the trac-bar. Anyone familiar with this problem? I get the noise only when the suspension is articulating. Sitting level, there is about, half inch gap between the spring and bracket. That seem to be about normal spacing?
Nothing looks out-of-wack, and by looking at the geometry, the 2" booster lift I have should actually pull the axle toward the drivers side, moving the spring further away from the trac-bar bracket.
I am running OEM springs and trac-bar. Infact, everything in the front is OEM, other than the 2" coil spacer. Let me know if you guys got any suggestions.
97 sport. I apologize if this should be in mod tech... dealing with OEM parts, with a not-so-much OEM lift, though, problem existed pre-lift as well :dunno:
Thanks!
Thanks!
