alex22
- CT: waterbury area
SOLVED. But I thought I would share it with the rest of you. It was this really anoying high pitch metal on metal squeaking comeing from the front end. Interesting thing was that it went away when i put the brakes on. I was all ready to pull the tires and brakes, check to see if all the bolts were tight, and then keep moving in.
Before I got started i saw that the bushing at the bottom end of the shock was worn out and the metal eye was rubbing on the axle. What a racket that thing made. I thought I was going to loose a tire at times. I'm going to be geting new shocks all around.
~Alex
~Alex
