BAMCHEROKEE88
NAXJA Member #976
- Lancaster,PA
OK, I`m still having problems with a stutter at a certain postion in the gas pedal and it will backfire if kept there. Before it would happen when above 45 and cruising on the highway. Now It will do it at 35 and above. It is ok when accellerating. I have now replaced the following: TPS, CPS, O2 sensor, MAP, MAT, EGR valve and gasket, CCV hose assembly, cleaned the throttle body (new gasket), cleaned the inside of the valvecover(needed new gasket), serpentine belt, plugs and wires (hope I remembered all of it). I still have some oil blow-by after cleaning the vavlecover so well you eat off of it and replacing the CCV hoses. Any other suggestions?
88 4.0L auto 126K miles
