1984-01 Jeep Cherokee (XJ) Wiring Info.
1984 Jeep Cherokee Stereo Information
Constant 12V+ Red/White
Switched 12V+ Purple/White
Ground Black
Illumination Blue/Red
Dimmer Orange/Black
Front Speakers
Left Front (+) Gray
Left Front (-) Brown/Red
Right Front (+) White/Red
Right Front (-) Yellow
Rear Speakers
Left Rear (+) Gray/White
Left Rear (-) Brown
Right Rear (+) White/Black
Right Rear (-) Brown/White
1984 Jeep Cherokee Ignition Information
Constant 12V+ [Red] Ignition Switch Harness
Starter Dark [Green] Ignition Switch Harness
Ignition [Yellow] Ignition Switch Harness
Accessory [Brown] Ignition Switch Harness
Tach [Green] Coil
Brake Switch [White] Brake Switch
Trunk Pin [Black (-)] Rear Light
Parking Lights [Dark Blue] Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger [Black(-)] Driver's Pin Switch
Door Lock [White] Driver's Kick Panel
Door Unlock Dark [Green] Driver's Kick Panel (Reverse Polarity)
1985-87 Jeep Cherokee Stereo Information
Switched 12V+ Purple/Orange
Ground Black
Dimmer Orange/Black
Antenna Trigger Gray
Front Speakers
Left Front (+) Green
Left Front (-) Black/White
Right Front (-) Black
Rear Speakers
Left Rear (+) Green/White
Left Rear (-) Brown/White
1985-87 Jeep Cherokee Ignition Information
Tach [Green] Coil
Hood Pin n/a
Factory Disarm n/a
Door Trigger [Black (-)] Driver's Pin Switch
Door Lock [White] Driver's Kick Panel Reverse Polarity
Door Unlock [Dark Green] Passenger's Kick (+)
Door Unlock [W/Keyless Light Green and Tan] Passenger's Kick (+)
Horn Wire [Black (-)] Steering Column
1988-90 Jeep Cherokee Stereo Information
Constant 12V+ Pink
Ground Black
Illumination Orange/Black
Dimmer Dark Blue/White
Front Speakers
Left Front (-) Black/Yellow
Rear Speakers
1988-90 Jeep Cherokee Ignition Information
Tach [Green] Coil
Trunk Release [Black/White] Manual Release
Trunk Pin n/a Works with Dome
Light Parking [Lights Blue (+)] Light Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger [Black/White (-)] Light under Dash
Windows Up [LF=Light Blue, RF=Brown/White]
Windows Down [LF=White, RF=Purple/White]
1988-90 Jeep Cherokee Cruise Information
Constant 12V+ [Red] Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ [Yellow] Ignition Switch Harness
Ground Use Chassis Near Cruise Control Module
Hot Side of Brake [n/a] Brake Switch
Cold Side of Brake [White] Brake Switch
Tach Green Coil VSS Lead [White/Orange] Harness from Transmission
Pulses Per Mile 8000 PPM
Notes: Vehicles with Manual Transmission require Clutch Switch. Some vehicles may require a speed signal generator and/or other parts/adapters not listed above. Rostra® Cruise module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
1991-92 Jeep Cherokee Stereo Information
Ground Black
Dimmer Red/Black
Antenna Trigger Purple/Orange
Front Speakers
Left Front (+) Gray
Left Front (-) Yellow
Right Front (-) Brown/Red
Rear Speakers
1991-92 Jeep Cherokee Ignition Information
Starter [Yellow/Green] Ignition Switch Harness
Ignition [Blue] Ignition Switch Harness
Accessory [Purple] Ignition Switch Harness
Tach [Green] Coil
Trunk Pin [n/a] Works with Dome Light
Parking Lights [Blue/Red] Driver's Kick Panel
Head Lamp [Brown/Black] Left of Steering Column
Hood Pin [n/a]
Factory Disarm [Green/Orange] (-) Driver's Kick Panel
Door Trigger [Yellow (-)] Light under Dash
Door Lock [Orange/Purple] Driver's Kick Panel
Door Unlock [Pink/Purple] Positive Trigger
1991-92 Jeep Cherokee Cruise Information
Switched 12V+ [Blue] Ignition Switch Harness
Tach Green Coil VSS Lead [White/Orange] Wire Harness from Transmission
1993-94 Jeep Cherokee Stereo Information
Constant 12V+ Pink
Ground Black
Illumination Light Blue/Red
Dimmer Orange
Front Speakers
Left Front (+) Dark Green
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Rear Speakers
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Light Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
1993-94 Jeep Cherokee Ignition Information
Constant 12V+ [Red/White] Ignition Switch Harness
Starter [Yellow/Blue] Ignition Switch Harness
Ignition [Blue/White] Ignition Switch Harness
Accessory [Black/Orange] Ignition Switch Harness
Tach [Black/Gray Or Black/White (-)] At Coil
Parking Lights [Blue/Red] Driver's Kick Panel Black Connector
Hood Pin [n/a]
Factory Disarm [Purple/Yellow (-)] Driver's Kick Panel
Door Lock [Orange/Purple] Driver's Kick Panel Gray Connector
Horn Wire [Black (-)] Steering Column Windows Up LF=White, RF=Brown/White
1993-94 Jeep Cherokee Cruise Information
Constant 12V+ [Red/White Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ [Blue/White] Ignition Switch Harness
Tach [Black/Gray Or Black/White (-)] At Coil VSS Lead White/Orange In Wire Harness from Transmission
1995-96 Jeep Cherokee Stereo Information
Constant 12V+ Pink
Ground Black
Dimmer Orange
Front Speakers
Rear Speakers
1995-96 Jeep Cherokee Ignition Information
Constant 12V+ [Red/White] or Red Ignition Switch Harness
Starter [Yellow/Blue or Yellow] Ignition Switch Harness
Ignition [Blue/White or Blue] Ignition Switch Harness
Ignition 2 [Purple] Ignition Switch Harness
Tach [Black/Gray Or Black/White (-)] At Coil Neutral Safety Wire Brown/Yellow (-) Switch on Transmission
Trunk Release [Pink/Black (+)] Driver's Kick Panel Rear Body Harness
Trunk Pin [n/a] Works with Dome Light Parking
Head Lamp [Tan/Black (+)] Light Switch
Hood Pin [n/a]
Factory Disarm [Purple/Yellow (-)] Driver's Kick Panel or Pin 10 BCM lower left Instrument Panel Door Trigger [Yellow (-)] Light under Dash
Horn Wire [Black/Red (-)] Steering Column
Windows Up [LF=White, RF=Brown/White, LR=Blue/White, RR=Green/White]
Windows Down [LF=Light Blue, RF=Purple/White, LR=Red/Black, RR=Gray/Black]
1995-96 Jeep Cherokee Cruise Information
Constant 12V+ [Red/White or Red] Ignition Switch Harness or Use Hot Side of Brake Switched 12V+ [Blue/White or Blue] Ignition Switch Harness
1997-01 Jeep Cherokee Stereo Information
Constant 12V+ Pink/Yellow
Switched 12V+ Red/White
Ground Black
Illumination Orange/Brown
Dimmer Black/Light Blue
Front Speakers
Rear Speakers
1997 Jeep Cherokee Ignition Information
Constant 12V+ Red/White or Red Ignition Switch Harness
Starter Yellow/Blue or Yellow Ignition Switch Harness
Ignition Blue/White or Blue Ignition Switch Harness
Ignition 2 Black/Orange Ignition Switch Harness
Accessory Black/White Ignition Switch Harness
Tach Gray Coil
Brake Switch White/Green Brake Switch
Trunk Release Pink/Black (+) Driver's Kick Panel Rear Body Harness
Trunk Pin Gray/Black (-) Hatch Back Switch
Parking Lights Black/Yellow (+) Light Switch
Head Lamp Light Green (+) Light Switch Door Trigger Yellow (-) Light under Dash Door Lock Pink/Purple (-) Either Kick Panel Door Unlock Orange/Purple (-)
Horn Wire Black/Red (-) Steering Column
Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
1997 Jeep Cherokee Cruise Information
Constant 12V+ Red/White or Red Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Blue/White or Blue Ignition Switch Harness
Hot Side of Brake n/a Brake Switch
Cold Side of Brake White/Green Brake Switch
Tach Gray Coil VSS Lead White/Orange PCM, Passenger's Firewall,32 Pin Plug
1998 Jeep Cherokee Ignition Information
Constant 12V+ Red/White Steering Column
Starter Yellow Low Current Ignition Switch Harness at Steering Column
Ignition Blue/Gray Ignition Switch Harness
Tach Gray/White In Black Connector at PCM
Brake Switch White/Tan Brake Switch
Trunk Pin Tan/Black (-) BCM
Parking Lights Dark Blue/Red (+) Left Kick Panel or Light Switch
Head Lamp Tan/Black (+) Light Switch
Factory Disarm Purple/Yellow Driver's Kick Panel
Door Lock Orange/Purple (-) Driver's Door/Orange/Black Passenger's Door
Door Unlock Pink/Black (-) Driver's/Passenger's Doors
Windows Up LF=Light Blue, RF=Brown/White, LR=Black/White, RR=Gray/Black Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
1998 Jeep Cherokee Cruise Information
Constant 12V+ Red/White Steering Column or Use Hot Side of Brake
Switched 12V+ Blue/Gray Ignition Switch Harness
Cold Side of Brake White/Tan Brake Switch
Tach Gray/White In Black Connector at PCM VSS Lead White/Orange PCM, Passenger's Firewall,32 Pin Connector
1999 Jeep Cherokee Ignition Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness
Starter Yellow Ignition Switch Harness
Ignition Blue Ignition Switch Harness
Tach Gray Coil Neutral Safety Wire Yellow (+) Ignition Switch
Head Lamp Purple/White (+) 26 Pin Connector Passenger's Kick Position S3 Junction BL
Door Trigger Yellow (-) Under Dash Light or Overhead Module
Door Lock Orange/Purple (-) Driver's Kick Panel
Door Unlock Pink/Purple (-) Must use Relays
Driver's Lock Blue
Driver's Unlock Blue/Red
1999 Jeep Cherokee Cruise Information
Constant 12V+ Pink/Black or Red Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+ Blue Ignition Switch Harness
Tach Gray Coil VSS Lead White/Orange 32 Pin Connector Position B27 PCM left Side Engine
2000-01 Jeep Cherokee Ignition Information
Constant 12V+ Red Ignition Switch Harness
Driver's Lock Orange/Black Junction Block
Driver's Unlock Pink/Black Junction Block Horn Wire Black/Red (-) Steering Column
2000-01 Jeep Cherokee Cruise Information
Constant 12V+ Red Ignition Switch Harness or Use Hot Side of Brake
