because it's an inverted y the draglink goes directly to the passenger knuckle.
http://www.rockcrawler.com/techreports/currie_steering/large_pics/pic08_stock.jpg
you need to straighten the passenger side wheel.
Adjust the tie rod so the toe is correct on the drivers side wheel
Then use the collar at the top of the draglink to adjust the steering wheel position.
The collar at the top of the draglink will not affect the toe adjustment drastically. It should be a simple re adjustment on the tie rod to correct it.
