I've just tightened the tilit steering column on my 89 XJ a couple of months back. I've managed to tighten those torx-bolts without unbolting the column from the dash. I've pulled the wheel with rented Autozone steering wheel puller, also used their lockplate compressor to remove the c-clip. I've found that tilting the wheel to the down-most position will allow the mutlfunction plate to clear the steering shaft, so that you can get to assembly below. Also, I've had to purchase a $25 OTC-SPX pivot pin tool to remove the pivot pins. Without this tool, you will have access to only one torx bolt out of 4.
