I need to take off the oem stableizer but it won't budge. Does the bolt screw out of the steering arm or does it just slide out by hitting the bolt with a hammer? Also does anyone know how to center the front axle?
you can rent a puller for it from any autoparts store, they should give you your money back in full (or almost in full) after you return the tool. thats how ive done it.
DO NOT HIT THE SCREW WITH A HAMMER!!! You need to get a pickle fork to remove it...if you do hit it with a hammer put the nut on it and hit the nut. If you mushroom the screw it will take much longer to get it out. I made this mistake and had to drill it out. Center the axle with the track bar...adjustable or bracket.
