Paul S
NAXJA Member #103
- Woodland Hills, CA
BrettM said:It's been over 6 months, so I could be remembering wrong, but I think PaulS told me in JV last November that he had the WJ setup and took it off after a short while because of terrible Ackerman characteristics.
Ackerman was only terrible when I tried running true hi-steer with an export drivers side kunckle. I ended up not using the hi-steer arm on the drivers side knuckle as it was so bad.
Running normal crossover stering with the WJ stuff worked ok & had good Ackerman. The problem with this was that even with the tierod over the knuckle, the tierod was way too low (the lower WJ steering arms are lower than standard 30 steering arms). The other thing I didn't like was the unequal length draglink & trackbar.
I ran this setup for about a year before doing the WJ stuff & would do it again if I had a 30:
It held-up great to 20 or so Hammer runs.
Paul
