Starting a build Need STUFF!
LYKOS
Bent Mountain Va
Hi all.
I'm starting the build on my 01' and I want to keep it as low buck as possible.
Here is my wish list:
5 15x8 Cragar Soft 8's or comparable wheel.
Bumpers, front and rear. I'm looking for the typical setup with recovery points and winch mount on the front and tire carrier on the rear. I know, EVERYONE wants a set. I'm just fishing and hoping I get lucky.
I need a drivers side window regulator
CD/player with aux plug for my Ipod
Overhead console?
My drivers seat is shot. I'm a lard ass so it stays broken. Any sort of good, solid front seats in grey would be considered.
SYE for np231
Driver shaft for a 3" lifted 4door XJ with a SYE
auto locker for a Low pinion Dana 30
Selectable locker for a 8.25 Corp rear.
4.11 gears
Adj. LCA's
Extended brake lines
Quick discos
Roof rack
Just post up if you have anything.
I'm located in Roanoke Va 24011
tractor parts on an XJ? Never thought of that.
If they can handle farming abuse they can handle anything you put it through, only thing i would do is change the joints out for a set of ballistic's
Look at XJs in the junkyard with 2.5 liter engines and see if any of them have 4.10/4.11 gears. If they do, find the least rusty/beat up one (lucky guy, living in VA) and pull both axles. Shouldn't cost you more than 300 bucks. Just hope the carrier bearings etc are ok, wheel bearings shouldn't be a big issue if you have to replace them, definitely easier/cheaper than buying gears and having them set, and you'll be disconnecting the rear axle to do the lift anyways and nearly disconnecting the front axle.
That's a good idea.
Got the seats taken care of, and hopefully the window regulator too!
