Mr. Clean
- (Bonita) San Diego, CA.
I believe this is correct:
http://autorepair.about.com/library/graphics//42276757-b.gif
There has been some discussion on this before, with multiple answers. Up until now I have been too lazy to look again, but I will go check mine and post back later.
EDIT: Ok, on mine, three relays only (no a/c), the relay closest to the firewall is the oxygen heater relay, in the middle is the B Latch relay, and the closest to the front grill is the fuel pump relay, and of course that doesn't match the graphic. I have confirmed this by pulling the relays with the engine running.
EDIT 2: Ok, the Chryco published FI training guide has them in a graphic as closest to firewall a/c; next is the B Latch; then fuel pump; and closest to the grill is the oxygen heater relay.
The FSM graphics showing the relays has a single base point with four arrows running to the relays and a list of the relays at the single point--worthless.
Thanks once again, you have been so helpful!!:thumbup: I will post up after I get it running.
