Jeff 98XJ WI
- Butternut, WI
Well, this might be a foolish idea from a $ perspective, but I went ahead and ordered a Stak4x4.com Dana 300 Replace A Case, 31 spline input and a t-case output rotor, a JB Conversions 32 spline Dana 300 Front output, a High Angle Driveline 32 spline output flange and a t-case brake caliper from tsmmfg.com.
Most of these components are shown here. I still need to order a 32 spline rear output and figure out how to mount the caliper. I'm also waiting for Stak to build the 31 spline input.
I am planning to mate the t-case to a 4:1 Klune that I bought used from a friend. It had been connected to a AX15 and NP205 so it has a 23 spline input and 31 spline output and came with a 3/4" aluminum spacer and 1/4" steel mounting foot.
Here's a shot of the 32 spline front output. The aluminum retainer is a Stak piece.
One has to use the Stak provided seal with the Stak R.A.C. front 32 spline output retainer as the seal provided in the JB kit is too small. BTW, Stak supplied the output retainer for the stock output too!
Here's a shot with the Klune against half of the Stak case.
Klune components next to half the case.
Here's a shot of the output flange/rotor/caliper.
I've been noticing little issues when collecting parts and putting them together. In the above pic one can see how little of the rotor is actually clamped between the pads. There looks to be about 1/2" of pad exposed, but the caliper cannot be positioned closer to the flange since it is already hitting it! This is the same rotor/flange/caliper that Stak and High Angle use on their outputs, so I guess this is just the way it works. You can see that the rotor is about 8 3/8" in diameter. Tom Woods also offers the same caliper and a rotor, but his rotor only measures 7.75". I wonder if the diameter of his flange is smaller though? In any case, there is work to be done figureing out how to mount the caliper and get as much of the rotor covered as possible.
When I first opened the Stak box I got no instructions. After a call and email to Stak, I got two pages of instructions.
During the call about the lack of instructions, Tony asked about the shifter rail housing and weather or not a certain hole was drilled all the way through. It was NOT. He said that was a problem they had recently discovered on the latest batch of these. He said he could send me a new piece or I could finish drilling the hole. I chose to finish drilling the hole. This piece that I was drilling on has two holes on the top for the springs and detent balls as well as two holes on the side to insert some "pills" between the shift rails. The pills prevent the rails from shifting one to high range and one to low range at the same time. In my piece, one of hte pill holes wasn't drilled completely through. It was an easy fix.
Here's a shot that shows the layout of the rails, shift forks, pills, springs, balls and the housing.
Her's one with the housing on it's side showing the holes for the pills as well as the plugs for the holes
Continued in next post due to too many images! Jeff
