RichP
- Effort, Pa
Lawn Cher' said:That'll be awhile, I think Mrs Eagle has returned to the nest.
yea I notice that too. It's annoying the way wives, PAINTING, home PIA projects cut into web time....
ECKSJAY said:How sure are you that it didn't peek when it rode on the trailer?
Rev Den said:There is a reason they are round. As stated earlier...you could...but why?
NotMatt said:The only thing I would be worried about is U-joints at that point, but by my book it's better to break a u-joint and have to replace that then to break the whole shaft and be done wheeling unless you have a spare. Just my 2 cents.
Bent said:There is always square bearings and caps w/ full squircle clips to keep the little rectangular buggers in place, The advantage of the square roller bearingsis that if they get worn you can flip 'em 90*. The square caps give you the added cost advantage of building your own yokes out of channel iron.
:wave:
i second that. i've seen TONS of pto shafts built like that (on ujoints). hell, my father has a 5 year old john deere 3 blade bush hog that has all square shafts on it. i know of a driveshaft shop that will balance square pto stuff. the key with higher driveshaft speeds while wheeling is that it has to be balanced good.BrettM said:this thread is rediculous.
I've seen tons of these on the trail, they work GREAT! They are indestructable, using 1/4wall hitch tubing you will bend/break the u-joint, yoke, or output shaft before the shaft.
the downsides is they will not balance over 20-30mph and they can be noisy (grease them a lot). If it's for a front shaft, you have selectable hubs, and you don't use 4hi, go for it. Or if it's a trailer queen and it never leaves low range, go for it front and rear.
xuv-this said:...it has to be balanced good.
yup somtime my grammars aint too good. (lol)aperworkLawn Cher' said:Balanced well.
Ditto.Rev Den said:Wow...they really exist...and for some good reasons. Guess I am not to old to learn, I sit..humbled.
ECKSJAY said:Not if you're using 1/4" hitch tubing. Fill it with sand and you probably wouldn't have to balance it.
