CobraMarty
- PM me any questions
Yes I finally pulled the trigger and did this.
Pre-Install- '98 XJ with 165,000 miles, compression tested to 165-170, installed new fuel pump/pressure regulator, seafoamed, new water pump, high flow cat and 2.5" magnaflow muffler and tubing, 62mm TB, upgraded ignition- coil, cap, wires, rotor, new plugs, new O2 sensors, and 703 injectors, Innovate wideband O2 sensor and gauge.
Parts- Initally bought a Banks revolver header but the #6 tube hit the s/c manifold. Found a ceramic coated Gibson SS header on Amazon which fit with 1/2"+ clearence on all pipes and manifold. Boost gauge and cool intercooler gauge with 2 sensors for pre and post temps, Sprintex S/C kit with AEM FIC-6 controller.
Install- After much reading and debating I did wrap the headers with header wrap and stuck on the Gold heat reflective barrier to the bottom of the new s/c intake manifold. I drilled and tapped 2 additional holes in the TB plenum for pre'supercharger temp sensor and a possible methanol injection and drilled the intake manifold for a boost gauge and the post supercharger temp sensor. The disassembly and install is very straight forward. No surprises. Just unbolt intake and exhaust and then reinstall the exhaust and new intake and supercharger.
The Good- It all fit as supplied. It started right up.
The Bad- the throttle cable bracket was too tall for my liking and I had to modify it to shorten the height. The bolt heads holding the new idler tensioner brachet were too thick and hit the belt and had to be ground down for clearence. The Volant CAI that I had now didn't fit because the s/c mounts the TB slightly higher and the Volant would not clear the hood so I had to buy a temporary air filter and crank case filter to fit.
