- MilkyWay Galaxy
This is not a tool thread, we have a forum for that. But many of us have simple low cost tricks or ways to test OEM things on our jeeps, besides the usual guess what is bad tactic, where you replace a part and hope your guess was right, which is usually the wrong guess about 6 times in a row and $400 later. Then it becomes an obvious,:twak: costly way to fix jeeps.
Obviously knowing how things work on a jeep is a great help, but once we get past that point, there are sometimes simple, easy little ways to figure out where the gremlins are hiding. These would be low cost, simple stealth methods of detecting cloaked Jeep gremlins!!!
So if you come up with one post it up in this thread and share it!!! One that I can think of that is not used often enough is thermal testing. For instance when a jeep dies only when it warms up, take a hair dryer and pre-heat the CPS to see if the jeep will start cold with a hot CPS, to see if it is the part that is dying when it gets hot. Repeat the test on say the High Voltage coil next!!!
Or if it will not start on cold mornings, use the hair dryer to heat the MAT or CTS temp sensors to see if it gets the rig to start.
I was thinking about a recent poster here that was not too savvy on wiring and electricals that had something draining his battery over night, and he was not familiar enough with multi meter use and wiring to figure out how to trace the parasitic gremlin load. I was thinking a relay might be stuck. Finally dawned on me that anything using enough power to drain a battery over night should get hot!!! So using the hand or an IR temp tester, one could shut the jeep off, come back an hour later and snoop for a hot relay, or wire!!!! Simple, quick, cheap test!!! Anything warmer than ambient temps!!!! So when you come up with one post it up here!!!
