I have a 1990 XJ 4.0, and I am in the middle of taking off my throttle body to give it a good cleaning.
While disconnecting the MAP sesnor vacuum tube, I broke the line in two, right at the elbow where plugs into the TB.
What can I do to replace this? Must I go to the dealer? Will my XJ be undriveable?
If I can find some really small vac hose, would be OK to use this as a temp fix until I can get a new MAP sensor vacuum tube?
Thanks!!!
Thanks!!!
