HJ88
- Washington
I've been having problems with the engine dying when I give it abit of throttle then take my foot completly off the gas, sometimes it goes back to idle, sometimes it goes down to 150 - 300rpm then back up to idle, and sometimes it just dies.. i've recently gotten a new ISSM (I think I messed mine up while cleaning it, while I was cleaning the TB) and I've readjusted the TPS to the correct reading... and it still dies.. now I'm thinking its the MAP sensor, perhaps not giving the correct response at lower rpm's and killing the engine... I've tested the input/output voltages on the MAPS and they come out fine (5.02v @ C, 4.82v @ B) but I dont have long enough probes to check the resistance between A and the ECU, although I suppose abit of wire would work so I'll try that tommorow.. (BTW, anyone know an easy way to check the wiring harness up to the ECU without pulling out the whole computer?)...
I've searched the boards and havent found anyone with quite the same problem (alotta people have Idle problems, but I can idle all day, just when I give it abit of gas while stopped then let off it wants to die or does..)
As always I appreciate all the help... I dont know how I'd get anything done without you guys (and gals)..
