I've considered the line locks / cutting brakes type stuff... seems more difficult to use. I'd love to have a switch for the front and a switch for the rear just like a full selectable locker, but all put together for less than the cost of a single autolocker. Not sure I'm going to be able to hit that goal and I know it won't stand up to the same kind of abuse, though.
We'll see. Now that I have a few more modulators (I've been calling the electronics part of the unit the HCU, and the metal block + valves the modulator, not sure if this is correct terminology) lined up to be available next weekend, I'm much less worried about irreparably damaging my first one by pulling it apart, so I'm going to just gut it and fully map the hydro circuits sometime. At this point I don't intend to make use of the stock HCU at all since it's all custom chips and stuff I can't reverse engineer easily, I may reuse the wheel signal processing/filtering portion of the circuit (I've never built something with reluctance pickups before, it may be easier than redesigning it) but that's about it.
Total spent so far:
$40 - WJ ABS module
$20 - WJ ABS sensors
$15ea - UP380046 brake lines (for the rear, going to run an extra line so the modulator can live in the engine compartment, though it could probably mount on the rear axle or under the rear seat)
$3 - 7/16-24 inverted flare plugs
Expected expenses:
* another two ABS modules (only one more required if someone else follows my steps on this, but I need an extra to pick apart for info) - we'll call these 10 each since I'm going to be getting two huge turbochargers, a WJ booster/MC, two WJ ABS modulators, a stack of coil on plug ignition modules, some spare dana 30 shafts, and a bunch of other junk all for $100
* tone rings - probably get these at the all you can carry
* costs of installing tone rings - find out which of my friends are machinists, bribe with beer as required
* custom electronics... this is definitely going to need some.
