garr
- Nassau County NY
I read this entire thread this morning, if your rear brakes are adjusted properly, and installed correctly, the only culprit is air in the system.
Based on what I've read, I would imagaine that the rear brakes are adjusted correctly, and installed correctly.
So, my professional opinion (with out my own eyes on it, and my own tools turning the bolts in my own shop, on my own rack) I'm going to draw the conclusion that you have air in the system. This air is located in the rear, and the only way it's coming out is by using the special tool to bleed the proportioning/metering valve. (technically called a combination valve) It's job is to delay fluid flow to the rear so the drums don't lock up instantly, and then meter the pressure during braking with waaayyy less to the drums, if it wasn't there, the drums would just self energize and lock up at every light.
All of that being said, there is a special tool to bleed that bastard, and I'm pretty sure it will solve your dillema. I've got a few different style in box at my facility, and I do not need them to often, but I have solved this issue on jeeps, trucks, SUVs, cars, station wagons, vans, anything with a disk front, drum rear with one if the aforementioned tools on many occasions.
WWW.tooltopia.com
Www.thetoolwarehouse.net
You can find the one you need at one of these vendors. If you were in Illinois by me (where brake lines rust, and brake repair about covers my overhead every month) Id tell you to stop by, and we'd get her done together. Let me know If i can help.
What tool do you recommend?
