tripdog
- San Diego, CA
I have a D35 and a LP D30, stock leafts, stock coils, drive shaft and some other miscellaneous stuff if anyone wants it.
I could use a stock tranny cross member if you have onetripdog said:I have a D35 and a LP D30, stock leafts, stock coils, drive shaft and some other miscellaneous stuff if anyone wants it.
Eddie G. said:I like to get the axle shafts out of that LP D30 if possible.
Thanx...Eddie
cracker said:Ummm. I call the drive shaft!!!! Eddie, can you grab it for me when you get the axle shafts.
tripdog said:I'll give the drive shaft to Cal...
jonboy said:I could use a stock tranny cross member if you have one
Aaron, can you bring it to big bear?99xjache said:I still have one from my 99/aw4. You can have if you want.
jonboy said:Aaron, can you bring it to big bear?
If the d35 is non cclip I'm interested in just the shafts (if you're willing to separate).cyberbackpacker said:Hopefully next week after 5 months of driving at 35mph, and two months after getting replacement axles, I will/should be swapping axles.
So I will have a HP disco D30 with at least the psgr side tube bent (possibly more) and a d35- non c-clip I believe. Both have factory 3.07s
I live with my in-laws and I am not going to be allowed to bring axles home after I swap in the new axles.
So this is a heads up... otherwise unfortunately they will be finding a dumpster after the swap.
If you want them, pm me to arrange pick-up.
-Kevin
cyberbackpacker
Cool, I'd appreciate it if you get a chance as my dad's rig could use a set of spares. If it's going to be too much trouble though don't worry about it.cyberbackpacker said:If we have the wherewithall at the end of the day to pull them, I can definitely do that... I can keep shafts in the back of the rig, but an entire housing would be ridiculous.
-Kevin
cyberbackpacker
You can have mine if you want it. It came off of my 95 and was good when I pulled it.steagall9301 said:BTT and i need a good but stock track bar, the newer the better. thanks
