Laurentide
- Burlington, VT
I was working on a hitch installation on my '99, using a breaker bar to get the exhaust hanger bolts out of the passenger side frame rail. They were holding the remains of the original hanger, which in turn was hiding a nasty rot hole. As I was using the bar on the last bolt (the one present in the pics), I peeled the whole frame apart:
Rear of hole:
Front of hole:
I'm obviously pretty bummed about this, as I've only had the vehicle for about 6 weeks, and I bought it to tow a small aluminum boat. There are a few other rot spots on the rails that I'd like to fix, but nothing like this gaping hole. The floor pans are solid, surprisingly, and the body is good for a '99.
I've never used a welder, but I'm willing to learn. Would this be too difficult for a novice? The guy at the local welding shop told me that he wouldn't weld anything with rust present, so that's not an option. If I'm going to drop the tank and cut and clean, I should probably just figure this out on my own. Am I thinking straight here, or throwing good time/money after bad?
Rear of hole:
Front of hole:
