Ou2mame
- Long island, ny
I soak down all my bolts for days before I touch them now.. Mix of acetone and atf. They slide out easy usually. What happened here is the end of the bolt was probably really rusty and it clogged the threads and got jammed. I would dremel a notch into it.. A really good one and try to turn it in with an impact gun, and then if you can see the bolt clean the threads off and lube it really well and then try removing it again.
Sent from my HTC M9 using Tapatalk
