fubar XJ
- Bothell, WA
I've had an issue off and (mostly) on with a very slow crank on first start of the day with my XJ. Did a search, found a couple of threads mentioning check your grounds. So two days ago I did, cleaned both battery posts and terminals, positive and negative posts/terms at the starter, post/terms at the engine block and body ground, issue persists.
The only thing remaining seems to be the starter solenoid. I'm guessing the inside connections of the solenoid must be fouled. I also had the problem "correct" itself after wheeling a couple weeks ago, guessing the jarring on the trail bumped the connectors closer together or dislodged some dirt/gunk. Now it's back to very slow crank. Alt is charging fine (13-14 volts) and I can't think of a single other issue that could be affecting it at this point besides the starter.
Thoughts?
Thoughts?
