That's not good.davidt said:it didn't just leak a little bit, it leaked a lot. But it leaks the worst when I pump the clutch. It is leaking out of the bellhousing BTW.
Replace the o-rings in them?davidt said:they are not threaded, they are the quick connect type. If they were threaded, life would be much easier.
it is a new cylinderotto said:If you're leaking fluid out of the bellhousing, your slave cylinder is shot. Means dropping the transmission to replace it on a 1990 AX-15.
