JBM
- Austin, Texas
Sorry to bother you guys with this. I figure it is a pretty simple question. I tried to use search but found nothing.
I just bought an 88 XJ and I pulled the transmission because it seems to have several leaks. On the name plate it says it is model number 30-40LE. Is this the AW4 I keep reading about?
Also the whole undercarriage of this XJ is covered in transmission fluid. I know it has been leaking for awhile. The problem is the front and rear seals look good. Is there some other place that is known for a leaking problem on these trannys?
Thanks in advance,
Jason
Thanks in advance,
Jason
