jamesonw23
- Enumclaw
So a few months ago I swapped my 2000 XJ's radiator with a CSF heavy duty 3 row. When I refilled it, I put in Dexcool which I recently found out is a big no. So the other day I flushed it with the garden hose by unplugging both the upper and lower hoses and basically letting water cycle through until it was clear. I ran it several times and let it get to running temp. I also ran some flush throught it and disconnected the overfill and flushed that as well. I replaced my thermostat and water pump to. My question is, should I redo the flush using the kit made by Prestone that comes with the tees to tap into the heater core hoses or did I most likely get everything out already? Thank you. -James
